Yesterday I put the bucket on my new dolly (plywood with 3 small Harbor Freight dollies underneath).....put a small block of wood under the subframe to keep it at the right heighth for when I re-installed it, fertilized the lawn, drove back up to the dolly/bucket, and it went on easy (the initial install was a lot harder)....now I've got it!!! going to cut the corners off on the edge of the dolly closest to the tractor so I can turn the front tires without them rubbing on and moving the dolly.....turning the tires so it's easier to get the impact on the 2 bottom bolts on each side. Someone earlier on the forum had said they thought it was easier if you put the bolt heads on the inside and the nuts on the outside......he was definitely right!!!!!! :thThumbsU Using one of those new rubber twisty ties that you can get at Home Depot to keep all the hydraulic hoses together and further from the exhaust.....those things work great for a lot of things....use them on my garden trailer/cart to fasten tools on the rail hooks, so they don't move. When I get the dolly tweeked, I'll post pix. Nice to know it will go on and off pretty easily once you get it "down". (maybe a 10 minute deal total, including the hydraulic hoses)
Fadz
