The four students I have in my Welding 2 class this year were not financially able to build a project of their own, so using some scrap metal I have salvaged and a few parts I have purchased, we are building a forklift to use around the shop. Target weight is about 500lbs. Started with an Ariens HT16 that the previous owner had taken the hydrostat linkage out of to replace the gas tank and couldn’t figure out how to put it all back together. The wiring was fried, but we reduced it down to one wire to start and one to kill and the motor runs good. The hood was trashed so we built a new frame work for a new seat and I bought a generator fuel tank from a surplus store. The hundred lb tractor weight hangs on the very rear ( previously the front.) I have a student welding up a bracket to mount the steering box from a JD GT that I got on ebay and soon we will have the steering figured out. Hydrostat is next.
My question is about the mast. I am planning on using two 6.5 foot pieces of c-channel as the uprights. I have done a lot of looking and have seen where people use wheels inside the channel to keep the lift plate from binding as it goes up and down. Before I did any research though, I had planned on using two lengths of garage door track welded in each channel with 4 garage door rollers (the kind with bearings) in each side that were mounted to the lift plate. Will this work? My father (who is a well-seasoned farmer/junk builder) seems to think it will not. I can't think of why it wouldn't. The only force that should be on the track will be the force of the forks trying to twist down as they are pulled up. I realize the further out the weight is on the forks, the more of the strain there will be, but I would think that 5oo lbs spread over 8 rollers would still be under the stress load of the track and rollers. I am thinking the forks will be about 40 to 42 inches. And I guess I should add that this will be a winch powered forklift.
Some pics of it currently. Sorry, my cell takes terrible pictures.
