Hi all. Rayjay asked that I post a follow-up message on how things have been since my L118's T40 was upgraded to K57 specs. To recap the history first, I have an L118 that came with a T40/K46. My 1/2 acre lawn has 40 foot run sloped at 10 degree in the front yard. In addition to mowing I haul wood thru the back area of my 6 acre wooded lot (some slopes there, too), dethatching and plug aerating. All was fine until I went out one day with the tranny release lever only partially engaged after having pushed the thing around the shed. I was running for about an hour before I realized what I had done. After that, my machine lost a lot of pull especially in warmer weather and running for 30 minutes. I couldn't even pull the dethatcher on anything other than perfectly flat ground. This happened at around 220 hours. At about 250 hours I decided it was time to fix the problem.
I looked at all the options and figured fixing the tranny was the most cost effective solution in the long run. While I have the ability to tackle the task, I didn't have the time so I shipped mine off to Duane at Tuff Torq to handle it and in the process had him upgrade the unit to the more durable T57 spec. It is arriving back today and we'll put it back together tomorrow. As Rayjay mentioned in one of his posts, the unit comes out of the tractor very easily and it went it just as easily.
UPS was a bit careless handling the unit when they shipped back to us. It appeared to have been upside-down in transit so oil ended up on the fan and on the top cushions of the box. I called Duane on his cell and he happily answered. He recommended checking the oil level and topping it off if necessary. It did turn out to be just slightly low so we added a bit more oil.
Once we were all put back together and running I definitely could tell the difference in performance. Reverse is faster now, as Duane said it would be, and power seems pretty consistent. I now have about 100 hours on it and it is still going strong. If anything, it might lose a smidge of speed after running for a while in hot weather, but that is debatable as there is plenty of power getting up hill. Certainly nothing like before the repair. I plan to drain the oil at the end of the season and replace the oil at the end of the season. I'll have to provide another update after that effort.
