Now that I've been around for a bit and done a whole lot more reading on these machines, I'm still a bit confused. Mostly I'm confused about how the engines factor into the tractor, and why some tractors work a lot different than others.
When I got mine, I figured a 22hp v-twin would be plenty powerful. I've had various Biggs engines in the past and never had any problems with them so I figured it would be pretty durable and reliable. I keep seeing people recommend other tractors to people and saying things like "it has the Kawasaki engine" as though that engine is significantly better than the Briggs or Kohler engines. Is there really that much difference? Like the Kawasaki engine in a Husqvarna tractor puts out 24 hp vs my Briggs 22, yet I still get the impression that people think the Kawasaki is a lot better engine to have.
How does the overall hp factor into the tractor anyway? If the transmission is a hydro, then transmission power is pretty much independant of engine power isn't it? Some of the old 8 hp tractors seem to do almost as well as modern 20+ hp tractors, so what's the difference?
And why is it that when you get to the higher end you end up with diesel engines? I thought the point of a diesel engine was to have more power at a lower rpm (1800rpm vs 3000 rpm), so do they run the same as a regular gas tractor in that they spin at the same rpm regardless of how fast you go? Or do they have some other mechanism for driving the mower blades and transmission?
There's so much I don't know...
