I recently bought a John Deere 2025R tractor. What size trailer do I need to haul it around? Thanks in advance.
Just for the heck of it I looked up a half-ton Ram pickup. The one I looked at was rated to tow just shy of 13,000lbs. That's more than capable of pulling a 3-4K tractor, and a 2,500lb. trailer. That being said, I agree, it should have a brake controller for the trailer brakes.The other consideration is the vehicle you will use to tow it. My 1/2 ton Chevy pulls it ok but but if the tractor is toward the front of the trailer it drops the rear of the truck quite a bit. Adding booster springs would help but then you loose the ride. The big thing I have seen though is the 1/2 ton does not have the stopping power for the weight. Under normal conditions where you make normal stops it is ok but a panic stop will scare the **** out of you! For a 1/2 ton truck you are getting to the point where trailer brakes are almost a necessity.
I am considering going to electric brakes on my 14 foot trailer. How do you like them? What mods did you need for the truck? Was it costly?I have a Kioti CS2210 SCUT, with FEL, and usually attach a rear ballast box or blade. It can weigh in at about 2,400 lbs, and I tow it with my Toyota Tacoma.
After much study, I bought a PJ model UK142, 77" x 14' utility trailer, with T/A, electric brakes on both axels, dovetail, Bulldog coupler, and heavy-duty ramps.
The dovetail prevents scraping with a mower deck or my front-mount snowblower, and the ramps are rated for the full trailer load. I love it. Cal
View attachment 2515822 View attachment 2515823
