I'm hoping that some of you know (much) more about rebuilding hydro trannies than I do! I've got an older C'man with a Hydro-Gear 319-0650, and it's had drive problems ever since I bought it second-hand. Another thread of mine has the specifics, but basically the tranny is weak and will frequently crap out, once it warms up—even after replacing the fluid, purging the system, symptoms remain the same: will barely climb slopes and just doesn't have much go-power (Kohler motor runs great, however).
So, I pulled the hydro out, split the case, and started looking for problems. First of all, it was obvious that this tranny has been worked on in the past: thick orange sealer was everywhere and applied very heavily. I looked all the surfaces, gears, parts over carefully, and I was surprised to see that the piston blocks look very good, and pistons were very smooth/tight in both the pump and motor blocks (maybe they were replaced at some earlier point?). Also, I couldn't find much in the way of metal shavings anywhere in the case.
I did notice that the two machined faces on the center section did not look very good (see photos), especially on the motor-side face. Am I correct in thinking that center section needs to be replaced? Can someone confirm? If the assembly is bad, is it possible to have the faces repaired at a machine shop?
All help, suggestions, wisecracks appreciated. Thanks!
