Years ago,my dad bought a kit for our Craftsman push mower he saw in Mechanix Illustrated magazine that allows you to use an electric drill to start the engine..all it consists of is what looks like a nut made onto a socket,that replaces the flywheel nut,and the top of the "socket" looks like pipe,that has a spiral slot made into it--and the "bit" that goes into the drill is noting but a peice of hex stock with 2 pins that fit onto those 2 slots...arranged so when the engine fires up,it will "twist" the drive bit out of engaugement...this engine was a Tecumseh that had the "pull up" style recoil,so there was no typical recoil over the flywheel to get in the way of ths special "nut"...but they did list other types for typical recoils ,that required some modifications...
This was back in the late 70's,before we had cordless tools of any value,so we used a 3/8" AC drill to start the mower...but the thing started so easily with the recoil,I rarely used the drill,only my dad used it--he had parkinsons and found pulling the rope quite difficult...I still have one part of that kit,and the box it came in,but I lost the drive bit part of it,but one wouldn't be hard to reproduce...I'll see if I can find the box and post up the name of the company and adress...(doubtfull it still exists today though!)...
I have used a monster 110V 5/8" drill I had as an engine starter many times...my biggest problem using it was the socket would usually stick to the flywheel nut as I pulled off the drill once the engine started,and it would rev up to 3600 rpms with the socket wobbling wildly,and it often flew off and became a missle!...I took out a window on my truck one day when that happened,thankfully it wasn't the windsheild...it'd put a nice dent in your skull I bet,if it clocked you...
