The beast in question (see avatar): 1997ish 22.5 Kohler 50" hydro gear 210 almost 1200 hrs.
Background: bought in to what manual said and never did oil / filter on the trans. Yeah, I know strike one and been reading on that. Generally, this thing is a beast and I use it hard (see avatar). Ground speed up hills fully loaded has been lagging lately. Replacing the 10+ yr old drive belt helped for a few weeks. While I was under doing that, checked all the mount brackets, fan, pulleys, neutral switch and linkage. Also checked oil level and found it full.
I usually put the rear in neutral (transport) to push it out of the basement. For last couple years have had to push the lever a lit bit to get it fully in neutral but that's likely just a linkage tweak. Want to say it would also roll a bit when lever back in drive mode.
The fail: pulling both tow mowers, going through heavy wet grass, heard a bang from the rear and it stopped moving entirely. Used my 4wd truck to drag it up the hill and take a closer look. The parking brake works and holds it. If I let the brake off, the thing will roll away like it's in neutral and yeah, checked that valve.
Jacked it up to get rear off ground, jumped the seat switch. Did find a broken axle mount bolt and the rear kinda wondering around a bit but tightened the other one and it at least stays in place. Drive belt is tight [enough]. Fire it up, clutch for blades work, let the brake off (tension drive belt) and can see fan and trans input pulley spinning.
Shift it through gears (tires still off ground) and it will spin the axles both forward and reverse. Grab the spinning tire and it stops, other side spins. Grab the other side, it stops. About where I quit and pushed it in the garage. Was able to roll it easy with transport valve in drive position and could hear gears moving in the rear while doing so.
At this point, feel pretty sure I broke a gear / shaft / gizmo in the axle and the pump is likely ok. Plan A is a used hydro assembly from a donor, Plan B is an identical tractor for sale reasonably close. Plan C is follow A to get it up and running then tear the axle open. Fixable or not, wanna do the autopsy.
So the question here is: are these axles actually repairable and does my current problem sound any kind of familiar?? I have repaired automotive transmissions so I think I can handle the wrenching end of it. Do parts exist or what kind of pain is it to find them? Is it likely to find one or two obviously broken parts or is it more likely to find every moving part worn down to the nub?
