A friend made a really nice V plow out of parts of a 275 gallon oil tank..
He put it on a old Murray riding mower a customer left at the salvage yard he worked at,he fixed the engine,a 2 cylinder opposed twin Briggs,that had a valve seat come loose--long story how he did that,irrelevant here,and to raise and lower the plow,he used a hydraulic pump/motor,switch, and the pistons off an old convertible car,which worked excellent..
Both of us could stand on the blade and it lifted us up like nothing..!
He arranged the lift mechanism so it also applied down pressure to the blade too..
He used it around the business to keep paths open,and after adding much weight & chains,it worked much better...
I was impressed ,one day we had about 18" of snow fall,and the riding mower was able to make the first pass thru deep drifts without getting hung up or needing multiple attempts to ram thru them,it just plodded along nicely..
Unfortunately,that was its best use--to plow only a path or a sidewalk--when you tried plowing a larger area,the snow spilled off the other side of the blade,even if you only used one half of the blade..you had to make a hundred passes to clear up all the spillover..but if someone wanted to just plow a walkway or sidewalk,the V plow is the way to go in my opinion..
I suppose someone could arrange a hinge in the middle of the blade like a "Boss" snowplow so it could be used as a straight blade instead of a "V" too..
