I have an older x540 that appears to be having a problem with the safety interlock system. The tractor starts fine. However, I cannot engage the PTO. I also noticed that getting off the seat no longer kills the engine and also I can start the engine without the brake pedal depressed. Since both the seat switch and brake switch don't seem to be functioning as they should along with the PTO not engaging I suspect the problem is the Electronic Control Module is not functioning as it should, but the curious thing is it starts fine. I did test the seat switch with an ohm meter and it seems to work as it should. Any other thoughts of what the problem might be before I replace the electronic control module?
Thanks,
Mark
Thanks,
Mark
