What front tire size do I need to replace tires?
18K views 20 replies 8 participants last post by  JohnW
#1 · (Edited)
All I know is that I have 16 inch rims on my 1952 8N. The tires on it now are vehicle tires of some kind that rub. I can feel bubbles along the tire wall, and they seem to be too wide. I think they may have tubes that are narrower than the tire itself. At this point I don't know the width of the rims. There seems to be several sizes in the agricultural 16 inch tires available. How can I determine what width I need?
Marshall
#2 ·
What are you using the tractor for? For mowing (lawn, finish) many use implement tires like the ones on my tractor (see garage for pic). For field work a tri rib is the best choice. Either a 5.00 or 6.00 16 should work for you, just decide on the type of tread you need.
#8 ·
We used wide front tires like that on Dad's 8N when the loader was on the tractor. The standard narrow front tires were not up to the loads imposed when loading hay.
The narrow, single rib, tires were used for all other work.
You may want to consider getting another set of narrower wheels.
Mike
#13 ·
I run 6.50X16 tri ribs on mine. The wider the tire gets the harder it is to turn.
Your current fronts look like auto radial tires to me. is it possible they were put on over another tire? They wouldn't hold up much weight if it was just an innertube under it and it is a loose fit.
I've had some 16ply airplane tires once that didn't need any air in them to hold my little fords up. The stem was not even in one of the tires.
#17 ·
is your radius arm bent in,looks like it but could also be a illusion .nice tires though.I was going to switch to 16",but I have the 19" now.
#19 ·
what was wrong with the center pin you mentioned?
#20 ·
The central axle pin was not all the way in. About one half inch sticking out the front of the tractor. It looks as though the bushing is keeping it from falling out. The axle has been resting partially on the bushing and partially on the pin. The bowed radius arms are contributing to the problem, because the axle is not resting on the pin's bushing where it should be.
