This massive hunk o' metal came with my tractor and while it works great, I'd sure love to be able to reverse it and use it as a drag as well. There are no visible pins holding it in place except for the one at the bottom of the main shaft, which I believe isn't holding it in place at all, I think it's there to hold the rotating arm up. The other, obvious, spots for there to be pins are empty so I'm not quite sure what's going on.
I've sprayed it with penetrating oils, used steel pipe to pry on it, whacked around it with a 4# hammer, and most recently even tried to push it free against an oak tree... this thing 'aint budging.
Is it just rust or is that derned pin at the bottom really holding this thing together?? Thanks in advance.
