progress is being made, I have to pull all the hardware back off and clean it up and prep it for paint. I also have to wire up control and limit switches. In addition I have to make proper clevis pins, at this point I have just been using long bolts where the pins shoud be. At this point I have been using a spare deep cycle battery for testing (you can see it in the backround). I am very happy with the performance of the winches for the investment, although the controllers are horribly clumsy. Fortunately I will not be using the supplied controllers when the project is complete. With the bucket, winches (2), steel, tow strap and electrics I have less than $600 in it. When setup for the lifting mode you can raise the bucket to 34 inches above the ground (bottom of bucket) with the bucket remaining level thru the entire lift I will try to get better pictures and possibly some video when I have it completed.
