At 15 years old, I was as dumb as a rock when it came to engine work. My dad's Deere 440 crawler, with a 2 cylinder gas engine, had been sitting in a field for several years with the exhaust pipe rotted out seizing up the engine. Determined to "fix it" and with little experience other than a couple small engine repairs, I pulled it apart. Head off, the pan off, and a gallon of "liquid wrench". After days of soaking in LW, no joy. Pounding pistons with a wood block, no joy. Dug a trench under the engine and laid down some lumber and used a squat house jack to jack up the crawler on one of the crank journals. (Like I said, I was dumber than a rock, maybe I still am). Each day I'd refill the bores with LW and do one more push on the jack handle to keep the weight of the crawler on the crank. Then, one morning I found that the pistons had moved about an inch overnight. Long story short, new rings, honed the bores, valves and seats cleaned, carb cleaning,(updraft type) and actually got that thing to run very well until it was sold. I wouldn't recommend this method but in my case, it worked, and the thing was probably a loss anyway, so "what the heck"....
Got a "how I got it unstuck" experience to share?
