I just got my John Deere. I notice that on sloped and wet grass/turf my rear tires spin. I was wondering if there are weights that I can attached to my John Deere? I have an S130 Model. Any help is appreciated. Thank you in advance!
Thank you for the heads up! I unfortunately have my S130. It was all I could afford at the time. Do you have link of where I can get these weights, or should I just talk to a dealer directly?S100 series is Not a Tractor I would recommend for a sloped Yard( the TLT 200 transmission) is for Fairly flat Yards .
That said Deere Makes a Rear weight Bracket for the S100 series That You Can put two 42LB suitcase weights On the rear of Your Tractor and
Deere does Make some 31lb wheel weights that will fit On Your Tractor as Long as there are Holes In the rear rim to supports them or you will have to drill holes![]()
