My first rear snow blade built form scratch
45K views 65 replies 27 participants last post by  bogieboy
#1 ·
Hi Folks, now my cab project is finish I start to built a rear snow blade.
I toke a hold 40 gallon hot water tank for the blade, reinforce witch right angle.
#6 ·
Re: Picture of rear snow blade built form scratch
Looks like a great job done. Is it built so that you can shave back the bankings of your driveway.:sidelaugh
It's more because I have to go close of garage door I do 5 driveways and every door have each side a 4 feet wall so need to pull the snow from the door so I can blow it away.
PS: I'm not fully bilingual so sometime I don’t understand the subtleties of the English language.:(
#7 ·
As long as you speak Tractor and Tractor your Bilingual here. I am an Anglophone and even I don't understand all the subtleties of the MTF language!
Nice work on the blade French Canadians are some of the best fabricators out there!
#8 ·
:thanku:
Tractor talk run in my family, some live in New Brunswick and Gaspésie so when we are all together guess what we talk about:sidelaugh
#10 ·
#11 ·
Nice work,
There have been a few times when that 12v jack went on sale at Canadian Tire i was tempted to get one for just that type of thing. It runs abit slow but from your video seems like it will do fine.
#12 ·
Nice work,
It's not fast like a real actuator but like you said its doing the job and I put an ammeter on, it only pull 1.8 amps to lift.
#13 ·
Might it be worth the extra effort to double face your blade
just in case you want to do a little back pushing instead of only
dragging?
Speaking for myself.....with a set-up like that.... I would be
really tempted to push back snow banks.
#15 ·
Nice job.
#19 ·
I watched your video. Nice looking blade. Your tractor will have no trouble pulling a car out of a snowbank, guess what will happen to the blade mount if you hit a piece of ice frozen to the ground while working. The tractor won't stop but the blade will.
Make a much stronger tongue and a much stronger connection to a stronger blade post.
Bob :rauch10:
#20 ·
Bob :rauch10:
Don’t worry it is not finish I intended to but 2x2 across to get directly to the frame and move the JD wait on it.
And the blade will be reinforce to, I use to have in the past (20 year or so) a pick up with a front fisher plow (8 feet) so I know what kind of damage ice could do.
#26 ·
Nice quick fab work you did. Can't wait to see it in action in the snow.:thThumbsU
