Got a 1998 John Deere LX188 that runs perfect, I have restored it to factory specs using the factory tech manuel. idles at a smooth 1550 rpms & runs at 3550 at full throttle just fine with no leaks anywhere. But after using mower no matter if its 5 minuets or 50 minuets with or without load, and after it is shut off about 1 minuet it will start to drip fuel out of the overflow tube on top of carburetor. I have taken a 1/4 inch fuel line installed it on the carb fuel supply tube & pressure tested the float needle to 10 psi with no leakage while motor is shut off. Now how can gas leak out of the overflow tube when the float needle does not leak?
