OK.. right off the top.. new battery 4-15-2015 & has 12.93 volts in it.. the owner had me look at it.. u could sit on seat.. both pedals down.. turn the key to start & nothin.. do this 5-6 times & she would roll the engine over & start.. it has a Kowie engine.. starter solenoid is mounted on the starter..
we ordered a new starter & solenoid for this.. JD wanted 80$$ just for the solenoid.. & another 400 for the starter.... the parts guy says they have been gettin both from an 'aftermarket '.. costin 123$$ for both.. it came in yesterday.. installed it today.. went to start & still no crankin.. can't even hear the solenoid operatin..
back out to JD.. tell them prob.. I also tell them I put volt meter on the small solenoid wire.. only get 1.15-1.20 volts.. they tell me a safety switch is bad.. so I get schematics from them.. PTO.. switch.. seat sw. nuetral safety on tranny.. & a brake switch.. now talk bout hard to get to.. they r for checkin.. PTO checked out good.. tranny did too.. seat was easy to get to but good.. BUT where the heck is the brake switch.. I don't find one on either pedals.. or a wire goin to it..
COM'ON.. JD.. I thought I was not blind.. so on to plan ##2.. some good years ago I made a solenoid 'test' cable.. just a simple gator clip for battery.. a push button switch & another gator for the solenoid stud.. I've found many a faulty solenoids with this.. just pull off the small wires & hook up mine.. (2 wire ones require one lug to b grounded with second jumper/gator)..
today I used this on both starters when mounted to engine.. sit on seat.. pedals down turn the key to 'ON'.. then push the test button.. I hear both starters move the solenoids on them.. see the gear engage the flywheel.. BUT the starter does NOT spin.. WHAT GIVES with the LX..
