I was hoping someone could point me in the right direction on what the correct engine speed under load should be. I recently finished an overhaul on the 590V (900 hrs), new rings, metal cam gear, oil/water pump gear, governor, gaskets, etc and have put the deck and powerflow back on. I followed TM1574 to properly adjust the throttle plate/choke arm/governor to roughly 3450 rpm on high. This is also the first time I have had a tach installed to check rpms.
When I engage the PTO the belts turn and the engine speed drops to ~2700 rpm, and stays stable there. This is just in the driveway, not cutting grass. Can anyone with a similar setup tell me if this sounds correct? It is a 48C deck with HD powerflow. My impression was that the governor/throttle should maintain the 3450, but I cannot find a position of the plate that gets me there. If I push it too far left the engine speed with no load is too high, and vice versa. I can manually push the governor arm counter clockwise when the PTO is engaged and can get the engine to ~3400 rpm. This is leading me to believe its an adjustment issue, not lack of power, but I am unable to adjust it so it does that on its own. I do believe the new governor gear is working properly as I can see it moving the arm when its running.
Other things I have confirmed:
Both cylinders are firing
New belts, greased deck spindles
PTO was replaced end of last season
Thanks in advance!
Thanks in advance!
