i am just curious, the hydrostatic transmission that is used in the 300 series JD's, was that designed for john deere or did other brands use it as well? i believe it was built by sunstrand correct?
The Peerless 2600 was built to accomodate the Sundstrand Series 1500 hydrostatic transmission the same as the Peerless 2500 was built for the Eaton hydros. Same rear end, different mountings for the hydros.Absolutely bullet-proof tranny.
I believe that Sustrand was a division of Tecumseh, which is out of business now.
Don't fear buying a 300 series because of that. This tranny will outlast you if you change the fluids and filters even half as often as the manual recommends.
--Justin
with the prices they charge, the parts business is a good one!how can deere justify still producing parts for 40 year old garden tractors?
Too true! The thousands made for GTs probably helped keep the costs down. Hydraulic technology doesn't get to be old for at least a half century and sometimes longer. The P/S pump in GM cars was developed by Vickers before WWII. It was also for the aviation industry.I suspect that the garden tractor version would never have been built if not for the aviation industry supplying the R&D money.
Well, my inline Sunstrand has 2500 hours on it in the last 34 years and still going strong, last time I used it. The parts that are user replaceable are mostly off the shelf. The one stickler is the input shaft, and that is very tough material.hey, im new here but this interests me. But the hydro makes me worrry. If parts were discontinued what could be done? I dont think it could be swapped to something else.... How long will parts for these sundstrand hydros be around???
