Today I got to try one out for the first time and boy was I in for a surprise
. It needed to be moved across the lot so I could get another mower in where it was so I fired it up, (not knowing anything about how to opperate it) killed it a couple times because of a "safety process" I'd like to call it that you had to go through in order to get it into gear, then finally I pulled the two levers back and went sideways. I could not get it to go backwords in a straight line! I couldn't! Whenever I'd pull both the levers back it would go sideways and this way and that, in other words it was pretty funny. I eventually got it over to where I needed it. A little later in the day I decided to go fool around with it because I was pretty discouraged with myself about how bad of an opperater I was with it and thought I might try an improve my skills with it. After about 10 minutes or so of playing around with it, I got a little better at it when I was moving slow atleaste, but man do they take some skill and concentration to opperate!
