Greetings. I'm new to this forum, and to my "new" 1997 F/NH 6610S. I have a little experience with tractors, having owned a MF135 for several years now, but have to admit that experience is pretty limited.
I have what may be a dumb newbie question: A few months ago, the 6610S started and ran OK. But, after a few months of neglect, it now refuses to start (not even a relay-click sound). On lifting the hood, I found a huge critter nest, probably a raccoon. Swinging the battery compartment out, and cleaning the nest out, I could see the cable to the battery temperature sensor chewed all up, and the sensor itself looking like it had been melted in the back. So, I went ahead and removed the sensor & made sure its wires weren't directly shorted out.
Then I tried my best to "do my homework" on this. Charged the battery, cleaned the battery terminal posts, made sure the gearbox was in neutral & the clutch depressed, checked no other wires broken, etc (I have the operator's manual, a PDF repair manual, and a parts catalog), checked the fuses. But, nothing. Dead silence when I turn the key, not even after I wired in a 200 ohm resistor in place of the dead temp sensor, as suggested in several places on-line.
So, let me ask: First, is there something dumb I need to know about starting this tractor (e.g., does the hood have to be closed for the engine to start?) Second, is the tractor supposed to start even if the battery temp sensor circuit is open (wires cut)? Third, I don't get why I don't at least see the instrument panel come to life. That sounds as if the starter switch isn't electrified. Finally, where should I begin trying to diagnose what's going on?
Thanks in advance. I feel like I'm in The Twilight Zone. Besides the pandemic, our JD Gator quit, our '96 Miata quit, and those two vehicles took months to diagnose and repair. It's as if the world went crazy.
I ordered a new battery temp sensor, but have the sneaking suspicion this alone won't solve the problem.
