Drag link help. LX188
13K views 17 replies 11 participants last post by  exptractoruser
#1 ·
So the end of the mowing season last year the drag link broke on the basket case LX188 I have. Been doing some shopping, and a new one is going to cost almost 100!! Well... that cant do. I havent been able to find a good used one... so im thinking of trying to fix it. One end is a replaceable joint... no probelm at all, I can work with that... the other... well not so much. JD for some reason had the joint on the one side made right into the arm. So when it wears... you replace the whole thing insted of just the joint... :banghead3 So has anyone out in JD land ever messed with one of these? Any ideas on a fix without replacing the whole thing? Ive thought of cutting and threading the end for a replaceable joint.... but not sure how with a z shapped rod like that.
So here is the pic of the part... any brainstorming ideas?? Thanks!
#2 ·
#7 ·
OK, well figured I had nothing to lose...
Picked up some replacement ends for this and started cutting!!
I still have to grind the welds down and touch up a few spots... but I think it will work!
#8 ·
Got her all done, and mounted up!! Works great. I did have to slightly ream out the holes in the steering arms. the replacements were a tick larger, also the studs were a tick longer, but a washer under it did the trick. So insted of almost $100 for a replacement, Im out the door for about 20 bucks!!! I like that.
#11 ·
Great job with the repair.
#17 ·
Actually just yesterday mine broke in the same exact spot I eliminated the ball and just put a bolt down through the steering link into the hole( a little smaller bolt than the hole) with a heavy duty nylon and a metal washer above the hole and same below with a locking nut ( not completely tigh, you need movement)... took me 15 minutes and was back out cutting my 3 acres. I ordered one just incase but I'd like to see how long this lasts out of curiosity. I really didn't think it could be that simple but ya never know unless you try! Good luck
#18 ·
I know this O P is several years old, but it's worth reviving as we can see above! IMO! When I was a kid my grandfather, used a bolt, and drilled holes lengthwise,(vertical), and horizontally, and tapped a hole for a small Zerk fitting. Parts weren't available, and if they we're he couldn't or wouldn't spend the extra money on something he could fix in the garage/shop! I wish I had a picture of that back then as I remember watching, and trying to help at a very young age! :)
ETU
