Hi all!
I have gotten hold of a 72" JD 7-Iron Flex-deck on a web auction. Like-new condition at a ridiculous price (equivalent to $625).
The Idea was to dock it to my F725 that I’ve previously upgraded to a 26hp motor. It would probably make for the most bad-*** F725 the world’s seen, right?
PTO RPM was similar and only other trouble I thought of was lifting capacity. The Flex-deck is HEAVY. (My motor change is mentioned in this thread: http://www.mytractorforum.com/12-jo...com/12-john-deere-forum/586642-f725-does-not-engage-pto-capacitor-involved.html)
I went on with it and got it running yesterday. Quite soon I realized that this is a heavy deck for the small F725. It takes a lot of work with the weight transfer and differential lock to be able to maneuver, but somehow it’s worth it in cut width.
However at this stage I realize that it really doesn’t mow very nice and after some looking into it, I find that it actually runs the wrong direction. Bummer! The PTO is turning different rotations on my F725 compared with JD 1445 or similar that has the 7-Iron Flex as factory fit.
I could probably source other blades as one solution, but I would still have the situation of the belt tensioners be sitting on the pulling side of the belt transmission which isn’t very nice. So instead I’m considering if it would be possible to change direction of rotation on the gearbox where PTO-shaft connects to on the machine side on the F725. The idea would be that the gearbox design might incorporate a support bearing on one of the gearbox’s axels and perhaps one of the pinion gears would be able to move to the other side? Perhaps no one knows and I need to put it apart to find out, but It would be nice to avoid disassembly if it’s not possible.
Or any other solution to my embarrassing problem would be highly appreciated. Are there perhaps interchangeable gearboxes running the other way available?
Also if someone could tell me the rated PTO RPM for the F725 I would be greatful. I've calculated it myself to approx 2000rpm by measuring the pulleys, but a spec-number would be nice.
A long thread to ask a simple question, but thought it might be interested with some history behind and also share my crazy projects.
It sure looks cool though, huh?
