I may regret this as I know these type of questions usually draw a certain type of answer, but I'm going to ask it anyways:
I'm looking at building a loader for my small garden tractor (Murray 46300B).
It's going to be fairly lightly used. A little scooping in mainly sand and mostly a powered wheel barrow for me otherwise. Around the home landscaping use.
Design and construction isn't an issue (thinking of following a Gravely design, scaled to my tractor), nor is working out the hydraulics.
Cost is another story. Like anyone, I'd like to keep the cost down yet still build something usable for my purposes.
Right now, I'm looking at pumps and control valves. Pricey things if you buy them new.
I do have some leftover stuff from snow plowing days though.
I've got a fisher MM1 belt driven pump and a set of cable actuated spool valves.
The pump I can figure out, I'll probably have to build a mule drive since my engine in vertical and the pump needs to be horizontal (integrated reservoir). It's a metal body reservoir, so extending the fill to add a remote reservoir is a snap. Mig and go. So it's usable for my needs, as an interim measure if nothing else (please don't go off track here and start commenting on the pump choice).
The spool valves are the issue. One side is good as it can be used to power up and down. But the other is the typical plow style where it will power the blade up and the other position is "float".
What I'm wondering is if I can make use of this valve assembly for the loader?
The bucket obviously can't have a "float" setting. It needs to hold whatever it has in the bucket in whatever position it's left in, for obvious reasons.
So the "lift" for the loader is the question. With this valve, I can power it up and hold it there. No worries on that. It's the "down" I'm thinking about. I'm pretty sure the weight of the bucket/arms is going to be fine to do whatever scooping I need. Like I said, it's only going to be light use at best. My real concern is the drop to the ground when pressure is relieved. I'm pretty sure I remember that the plow dropped fairly uncontrolled on this valve when "down/float" was selected. It wasn't much of a concern as the plow didn't have far to go. But a loader that may be 4-6 feet in the air with a couple hundred pounds of something in it is a different story.
I sure would like to be able to save 200-400 bucks on the initial build by re-using this valve assembly. At least until I can build up more cash to purchase a more applicable set of spools.
Anyone see any problems with using it besides what I've mentioned here?
My biggest concern is that bucket dropping under freefall from any height of significance with or without a load in it. But I can also mitigate that concern by not lifting it over a couple feet while using this particular valve. Not a perfect solution, but one that can get me over the "cash hump" for while to where I can buy a better valve.
Please, lets not get into drawn out discussions on flow rates, geometry, whether or not something is a "stupid idea", "it's old", "how are you going to mount it", "it's not for that application" or any of that type of stuff. I'm aware of those technical issues.
I'm just looking for general thoughts to using it for a while (to save $$ on initial build) that I might have missed here. Mostly any safety concerns.
:tango_face_smile:
:tango_face_smile:
