Hello Guys, some of you probably helped me out on an earlier post when I was having a heck of a time sorting out an intake manifold problem with this same engine. Well it's back together and runs fine. The problem is that it's using way more fuel than it should. For those of you that didn't follow my intake problems I'll fill you all in on what I've done so far. Replaced intake end gasgets, and replaced the sealer in the intake seam. So there are no intake problems. Replaced the fiber float with a brass float and set the float level at 1/8". Installed carb, and fuel pump kit. Now the engine runs fine but it's using tons of fuel. I used the tractor yesterday for a couple of hrs, and it ran fine with tons of power. But while I was using it I noticed that it smelled like it was running rich. I brought it back to the barn and pulled the plugs and they are totally BLACK. When I put it back together after I rebuilt the carb I opened the main fuel 1 1/4 turn, and the idle 1 turn. It started and ran fine. After it warmed up I adjusted the idle mix to where the engine idled the smoothest, but didn't do anything with the main jet adjustment so I think it needs some attention. What is the best way to adjust the main jet? I was thinking maybe warm the engine up to and put it at approx. 1/2 throttle and adjust the main jet to get the highest RPM? I'm obviously not a carb expert and I need some advice from some of You guys that have more knowledge than me. By the looks of the spark plugs this thing is running way too rich. Any advice/suggestions would sure be appreciated. Thanks, Litz
