B&S 42 Opp. Twin Leaking
2.2K views 14 replies 6 participants last post by  no2498
#1 ·
Briggs Opposed (42A707 1238-1) on an MTD 828 (146S828H013)
Following a full gasket replacement 1 hour into operation I checked around the sump and other areas for leaks. Everything was torqued to specification.
Cylinder two valve cover plate and surrounding area extending to Exhaust port but limited to the bottom of the VC is getting coated with black oil.
First instance I had seen it, it definitely looked like it's being "sprayed" rather than dripping. I cleaned it up once or twice to try and pinpoint the leak and didn't have much success. Judging by the direction of the "spray" it appeared it would be coming from the exhaust (flange/pipe style manifold). Now it's getting fairly wet.
I put some muffler weld on the connection to the flange and pipe and cleaned the area just to see if the spray would go away and it seemed like it did? Vaguely, if at all. The Muffler weld didn't last long enough to really give me an idea. Thankfully anyways, it was promptly removed after trying the idea. No plans on leaving it there.
I would almost wager the previous owner had the same issue, as the fins on the underside of Cyl. Two were a mess, which is also where this spray is hitting as well as the sump.
Prior to my rebuild I used some hi temp RTV to seal the VC's temporarily and didn't have this issue as far as I saw. I didn't run the engine for more than 10 minutes altogether before I decided to replace gaskets.
Plugs are good, engine makes good power, oil level is good and fresh. Entire sump was cleaned of any nasty gunk while rebuilding, making me curious where the "black" color is coming from, also leading me to believe it's something to do with the exhaust.
Thanks in advance, sorry for any useless information I may have included.
#2 ·
Need some images.
The first thing that comes to mind is crankcase breathing. The pressure in the crankcase varies as the pistons move in their stroke, so you will have pulses of pressure and decrease(not likely vacuum, but a definite bump). That can cause oil to be forced out the weakest spot.
tom
#4 ·
Looking at this image:
There seem to be no 'places' to leak oil except a flaw in the casting or coming from the exhaust port(bad or loose valve guides?). Other option is the drool method, where oil comes from up high and drools down the block.
A final would be an upper leak that is being blown down the side of the block caused by the airflow from the flywheel blower.
I don't think it is a fun task, but maybe consider removing the 'tins' - the shrouding that directs cooling air to see if there is a leak that is flowing down, assisted by airflow. There is nothing under pressure to cause a 'spray' of oil, so the only 'mover' would be cooling airflow. I think.
tom
#6 ·
tom
That's what I'm coming up with as well. There's nothing to "leak" on the engine except the sump.
I like your idea about the airflow causing the spray. I'm going to clean the area today and put some flour or whatever similar I can find on the area and try running again to pinpoint it.
The only reason this is puzzling me is because it's black oil rather than the fresh stuff I put in and the immediate area.
I inspected the block and rest of engine when I had it apart, I didn't find anything out of the ordinary. The back of my head says a cracked cylinder but this is an Iron Sleeved block so I'm thinking likely not. It had to have gotten super hot and other damage would have surely occurred to consider a cracked cyl.
If you look at my Cyl #1 Picture you can see some leakage running down the exhaust towards the top of the photo. Something else to look at? The fit on the flanges wasnt particularly great when I installed it but didn't think it would cause a problem.
I inspected the valves as well and cleaned up their seats when I had the engine apart. Nothing seemed out of the ordinary and the engine doesn't smoke like it's burning oil.
Thanks for your help!
#5 ·
I don't want to attempt to mess with what the site did with my above post, but it should be referring to an image of a 42A707 engine block, looking at it end-on from the side where you can see the exhaust ports for both cylinders, looking into the crankcase. Visually and logically, there's nothing to deliver oil anywhere near the exhaust ports.
I do not know what it will show if you click, so I added this...
tom
#7 ·
Have you checked the gasket on the valve spring chamber cover? Checked that there is good drainback(open) from the chamber? That area on both sides likely could have some old black oil... if the drain was obstructed. I do not know these engines up close & personal, just the generic style. If there is a problem with crankcase ventilation, the chambers are often a source of leakage as the gaskets used get tired over time and seem to allow for relax of the fit and then seepage.
tom
#9 ·
I replaced all gaskets and seals with new around the engine, top and bottom. And I strongly believe I installed the notches on the gasket/cover plate the right direction but if nothing else seems to be the culprit I may have to take another look.
When I had it apart I ran wire through all the oil galleries leading to and from the valvetrain(s). I'd say the only thing I skimped on cleaning at all is the area on the bottom of the back cover plate on the block, there's 2 small voids down there with some galleries, not really sure what purpose they actually serve but thats the only thing that didn't get made spotless. The rest of the engine was cleaned very well.
To tomw's point, I had an unexplained oil leak on my opposed twin. It ended up being the top oil seal on the crankshaft. It was dripping/being blown down.
I'll have to take a closer look at the flywheel side. The only confusing part about my issue is the concentrated area where this "black spray" accumulates. I need to bust out the talcum powder or flour and look closer.
I haven't had the time lately sadly. Old man winter has been pretty lax this year but that just opens opportunities to do other chores and not play with Tractors haha
Thanks for your help guys.
#10 ·
The valve gallery breather can not be put on upside down, screw holes will not match. The distance between the fiber disc in the breather and its' seat is a max. of .040". Do not push on the fiber disc or it will ruin it! Be sure disc is moving freely. Bleed hole in breather is open AND drain from chamber and crankcase is clear.
Walt Conner
#12 ·
Going a little off-topic here but to those who installed a fuel cut-off valve on a twin cylinder engine~ Have you ever encountered 1 plug reading lean and one reading rich after killing the engine by fuel starvation? I didn't notice this difference before I installed the cut-off and used the key to turn the engine off.
#13 ·
Did not read all of your replies, but for oil leaks that are hard to determine their starting source you can go to O-Reillys and get a little bottle of DYE for motor oil, call dye kit
Also get a pair of UV glasses and the UV flashlite if this is not in the kit and run the motor until you see little bit of oil and inspect immediately in a dark room. Do not wait too long to clean off the dye, it dries fast. The reason you need to remove the dye fast is because you may want to test again after doing repairs. If the dye dries before you get it removed just use some fast dry spray paint over the dye for a re-test.
Be aware that their are dye kits for coolant, AC, transmissions, motor oils, so get the correct kit. Kit is about $15.
