I have a John Deere 318, M00318X368388, with an Onan B43G engine. 600+ hours on the meter. I bought it used and have used it for the last couple years mostly to cut grass. It has always seemed to run hot - you can feel heat coming off the engine while sitting on the seat. It uses a pint of oil around every 6-8 hours. Recently it seems like it is losing some power on some days but then runs fine other days. The exhaust also seems to be popping louder. It will also backfire after turning it off sometimes.
I keep the cooling fins and the belly screen clear.
I don't know if all the symptoms go together, but thought I'd list them just in case.
Thoughts on what the issue(s) might be?
