I've owned the unit since 1976 with very few problems. Last summer, during several separate uses in hot weather (mowing w/rotary mower), engine quit after about 30 minutes. I could get it to keep running at low RPM's for a minute or so by playing with the choke but eventually, no go. After sitting in the field overnight, the unit would start fine but then do the same thing. My first thought was carburator blockage but I thought once blocked, the engine wouldn't restart until the carb prob was resolved. I then thought maybe it was a vapor locking deal because at the time the engine was balking, air bubbles were visible in the glass sediment bowl in the fuel line. When running normally, that bowl is filled with fuel and there are no bubbles. At present, the engine will not even fire. Spark seems to be good.
I'm going to start by having the carb rebuilt.
Other factors include: the original fuel filter, a nylon tube/screen in the fuel tank is no longer in place. I removed it after fiinding it rolling around on the bottom of the tank several years ago.
I guess the advice I'm looking for is - can I install an in-line filter in the fuel line and do away with the glass sediment bowl?
Thanks
Thanks
