1025R Broken drain Plug ?????
6.2K views 16 replies 9 participants last post by  Trentofdestiny
#1 ·
hey, I have a 1025R tractor and was going over some down tree cuttings, and not sure what I did to cause a leak under it. maybe drain plug?, after parking the tractor I noticed what looks like a good amount of oil leaking, maybe hydraulic or motor oil. maybe someone can tell me what part number I would need to replace the broken item by looking at the picture. not sure if it was related to my problem but it looked like a red washer and some kind of plastic piece was in the oil spot, might have nothing to do with the tractor but figured I add what I seen, it could have been on the floor prior to parking in the spot.
2493803
2493804
#4 ·
Pretty sure that is not the drain plug. Go to the Deere parts catalog site to see some pictures. But I agree with @Trentofdestiny that it is probably a switch/sensor and the red plastic is probably part of it.
You will likely need to remove the old one which will probably lose some fluid. You might want to take the time to change the fluid, since it might be hard to get the new one in without losing quite a bit of fluid. You also should thoroughly clean all the area around it before taking it out as you don't want to accidentally get any dirt in the system.
#9 ·
Just a note - if you find yourself hooking stuff that rips wires off of sensors and switches down by the transmission - you may wish to invest in a skid-plate for the transmission for when you do that kind of work....
otherwise, if you ride up onto a rock with your aluminum transmission case, and crack it - you'll be looking at a $2000-$4000 repair.
#11 ·
Yeah, if you plan on ever doing this kind of work again, you should get skid plates. While the 1 series has significantly greater clearance than even an X738 (let alone the X739) it is still very easy to cause very expensive damage very quickly. I have a CUT and there are parts that are pretty easy to damage, but they are more than a foot above the ground. It also has a cast iron transaxle. The 1 series has stuff several inches lower and not quite as strong.
#13 ·
Folks also need to be periodically reminded that these are sub-compact tractors, not Skidders. :)
#12 ·
Welcome to MTF Steve 1025R! As you can see lots of info and great members to help and share with, enjoy the site! I moved your thread to the JD SCUT forum so that you will have folks that know the machine better. Here is some site navigation assistance in case you need it:
2493810
