Well except for a few frayed spots I now have 2 unbroken belts that have imo stretched out.
I don't know but in my experience they'd work if I could tighten them up...
...is there a way I can tighten up the PTO belt?
Thanks.
Just some further skinny I'm throwing out to the forum.
While conducting routine mowing operations under almost perfect PM conditions the PTO belt came off. Put it back on it would cut for awhile then throw off again.
Observed belt while engaged by the PTO and noticed a very distinct wobble from the deck drive pulley. After a few minutes the deck pulley would throw off the belt again.
Took deck off and manhandled pulley to see if pulley needed new bearings. FYI I replaced both pulley sealed bearings about 60 hours ago.
Well the pulley seemed fine to me so I mounted up deck with a new belt & observed that the pulley wobble was gone and the machine cuts fine again.
2 things on my mind here that's driven by the cost of replacement belts.
1 If I could tighten up the belt like the previous mule drive pulleys things would be rosy.
2 If the deck pto drive pulley had more of a sidewall the belt would set deeper and would not kick out. Then again the wobble might still be there and that can't be good either.
In my mind I'm maybe thinking modding a stepped holding device for the otherwise static belt tensioned rod.
^So what do you guys think about that possible solution? Thanks again for all the good info I get here. The little lady has planed the day out for me so I'll be back later.
PS I use OEM belts
raying::thanku:
Thanks.
PS I use OEM belts
