I learned on old machines there is a lot of rust cleaning it can be a pain wire wheel ,sandblasting that may pot holes in tin. I have a better way to do it with a battery ,washing soda and water; I cut a 40 gal plastic drum in half wire tied 6 piec of rebar to it ran a copper wire to each rebar kept rebar about 1 inch from bottom of drum filled with water put 1 tablespoon of washing soda per gal. would be 20 heaping tablespoons mixed it up till no sign of soda is seen took 12 battery charger that isn't automatic hooked pos or red lead to rebar hang parts to be derusted on a wooden stick with mechanic wire hooked neg or black lead to parts hanging in water depending on how bad they are ran it for 5 hrs took out and used a preasure washer to clean them presto most of the rust if not all is gone seems to remove lead paint too, after dry a light sanding or wire brushing then paint parts lok like new . U tube has lots on removing rust through electrolysis
