I have a JD x595 w/3 point and loader. Is there a way to shut off the 3 point rear hydraulics when I use the Loader? Very frustrating that every time I tilt the bucket the 3 point moves with it! Thanx for the help!
The deere system was never designed to completly bypass the hydraulic cylinder on purpose. That is why they came up with what khodges is showing in the picture. since you say you have a aftermerket tru cat 1 3point did you also change the hydraulic cylinder on the tractor as well that controls the lift of the hitch. if not it is still rated to lift 450lbs. :thThumbsU
My 2003 X485 came with a limted cat 1 hitch in 2003 that had 26inch spread in the rear just like Khodges X700 series limited Cat 1 3point hitch. Khodges Deere call's it limted because of weight they also call the 2305's cat1 hitch a limted cat 1 hitch because of the weight it can lift. a True cat 1 hitch can lift atleast a 1000lbs or greater.:thThumbsU
Related Threads
My Tractor Forum
posts
4.4M
members
246K
Since
2005
