My biggest gripe about my x534: Once I get the deck leveled, a sharp left turn around a tree causes the right side to cut lower.
The solution that I dislike: Set the anti-scalp wheels quite low. The problem is that they basically have to be rolling on the ground in order for this to be effective. That means that the deck is experiencing a pretty rough ride when I go across small bumps, and I fear that hitting a large bump may jolt the deck so much that things break.
Why does this happen? My guess is that when all the wheels rotate for a left-hand turn, the entire mower goes slightly out of level. Such a wide deck makes this pretty noticeable.
Have any of you dealt with this issue?
