Hello,
Someone give me this
Troy Bilt - Briggs And Stratton 8HP
for free,and i knew that it has a problem and it was incomplete with 1 tire missing and also the cutters/bolts & belt.
So when i had little time to inspect the engine before i put any other money into it, i find out that the engine has a broken main rod in it! and rust on the crank,etc. So i decide it to see if i can put other engine in it.
Manley will use this to dig the dirt for my garden , witch is about 32 feet x 24 feet.
Now for a while i have look on craiglist for a motor or just to buy other one, fully working, but because i found no motor and price is little on the high side for a complete one, i decided to see if i can buy a used or new motor for it.
Here is my info from the engine :
Model: 195432
Type: 0149-01
Code: 81120910
8HP, AT 3600 RPM 319CC , 4 Cycle Engine
Briggs & Stratton I/C Series Engine.
Now, i was looking on Harbor Freight and from reading ,they have few that may fit in it. (see pictures)
The only problem i have to see if it will fit into my pulley, as my shaft is 2 1/2 inches long and 3/4 in diameter, also the 4 screws that holds the engine to the tiller are 2 1/2 between them.
My other question is! let say they fit okay! , how about the power "cc" mine has 319cc @ 8hp and the cheap one at Harbor Freight is 6hp @ 212cc , is that enough power to do the job?
I have also added few pictures of my tiller.
Thank you for any help and advice on this.
Regards,
P.
Model: 195432
Type: 0149-01
Code: 81120910
Regards,
P.
