Background – this is a “new to me” 318 with the P218G Onan engine [I’ve read as much as I can find here on mtf looking for ideas]
The engine would quit after running a while (10 – 15 minutes) when I first got it. I did verify that the coil was bad and replaced that (see this thread http://www.mytractorforum.com/showthread.php?t=198850)
It will still quit after it warms up. It’s like it is shut off when it dies, so I was assuming an electrical issue. Today I ran it at ½ throttle for 15 minutes without a problem. As soon as I went to full throttle it died within 30 seconds. I was able to restart and move it some at ½ throttle, but it quit again within 30 seconds.
When I measure voltage at the positive terminal of the coil after it quits, I have about 1 volt less than battery voltage. (Eg, today it was 11.4 volts at the coil, while the battery was 12.4). I measured this as soon as the engine died – the key was still in the on position (obviously). Interestingly, when I turned the key off and back on, the voltage at the coil was 12.0 volts versus the battery at 12.4 volts.
I checked the battery while running and it was greater than 13 volts so I assume the voltage regulator and charging system are working. (I have no idea how old the battery is, although it appears relatively new).
Can I assume that since I have nominally 12 volts at the coil when it dies (hot), that the TDM and other electronics are OK? Or, are there some other tests I can perform?
I did check the relief hole in the gas cap and it looks clear.
I’m wondering if this is a carb issue … I know it wouldn’t hurt to clean it up, but I want to focus on getting it running first.
Any thoughts?
TIA,
Gary
Any thoughts?
TIA,
Gary
