Okay, I read somewhere that if you wire the ignition switch wrong on an ST tractor with mag you can destroy the magneto. I'd like to avoid that.
Parked tractor Monday after mowing the lawn. Time to mow again but the ST/16 does nothing when I turn the switch. Model 917.25743
checked battery voltage - 12.6V
checked connections at the starter
" " " " " solenoid
plugged and unplugged safety switches a couple of times
No Change, nothing.
I bypassed safety switches to test, still nothing as far as starting but I noticed a weak spark between the bypass wire and sw. spade.
So I think maybe the switch is bad. Pulled it out to see lots of green/corrosion around the spades.
Okay, I have a bag of new switches on hand, bag tag says 31 2941, I'll change that out.
Hit a snag at this point. Both old and new are 5 blade but not the same as far as spade markings go.
New sw. has 3 spades marked an S, a M and a G.
I have long since cut the plug off that use to plug into the back of the sw. because it was corroded beyond use, so the wires are separated already with individual female spades.
Can anybody give me the scoop on S,M and G plus the wire color code for the other two spades?
I'm sorry this is so long - help please help me!
" " " " " solenoid
No Change, nothing.
