Greetings Everybody,
A question about the augers on snow blowers. I've seen many pictures of various snow blowers, to include many of our beloved Gravely blowers. On some blowers, the augers are mounted symmetrical so the inner end of the augers are next to each other on the same side of the auger shaft (in phase with one another). On other blowers, I've seen the augers mounted asymmetrical (out of phase) so the inner ends of the augers are on opposite sides of the auger shaft.
Some augers use offset shear pins on the shafts so they can only be secured on the auger shaft one way (this does not apply to Gravely blowers, at least not mine). At the risk of pointing out the obvious, my 210 Snow Cannon has two augers separated by the auger gear box. Each auger has the end clutch on the auger shaft so with some persuasion you can rotate each auger independently of the other.
I've tried using my cannon both ways, A
with the inner auger ends aligned with each other on the same side of the auger shaft and B.) with the inner ends on opposite sides of the auger shaft. Could not tell a lot of difference, but it seemed to work better when they were in position A as that pumped snow in from both sides at the same time, which seemed to force it into the impeller better and prevent clogging. That said, it was somewhat hard to tell as both configurations got the job done.
Welcome any and all comments on how the augers are suppose to be oriented to each other and/or opinions on why there is so much variance out there in the world of snow blowers. Symmetrical verses asymmetrical, which is it?
Thanks....
Thanks....
