Running Rotella T 15w-40 with good results
5.5K views 17 replies 8 participants last post by  LilysDad
#1 ·
My 310-8 would put out a blue puff of smoke after idling for a few minutes then going full throttle, then it would clear out. I figure the valve guide seals are worn. I had been running 30w oil in it but when I drained it it was like water. I tried Rotella 15w-40 and I am impressed how the smoking is reduced!
#2 ·
Heavier weight oil will do that. I ran that thru my WH last year, but soon changed it out. I read on the bottle it was good for winter, but it was so thick, I soon went to 10-30.
#4 ·
I run nothing but that Rotella 15w40T in ALL my engines, from my push mower to my V8 diesel farm tractors.....year round. Have for years, no probs at all. As to anything that swells seals, I won't use it. When you swell seals, they become very fragile. Best to just put new seals in.
#8 ·
So you guys run multi-weight synethics in your older Wheel Horses? I have always run straight 30W dino oil in my 520H but would like to switch to synthetic for my annual, fall oil change. I can not find anyone that makes straight 30W in a synthetic. The owners manual spec's 30W for temps above 30 degrees. I won't be using the WH for winter work. Am I safe to use a 10W-30 or 15W-40 synethics, and if so, what blend is best? Thanks
#12 ·
I've heard about those too! I imagine if you were to find them anywhere, it would be JC Whitney. :eck34:
on edit: Seems like I saw some 12v stick on tank heaters for RVs. These might just work on the bottom of a horizontal shaft engine. I seem to recall that they were roughly 12"x12".
#10 ·
CHD, Royal Purple makes a full syn 30wt
#16 ·
For me, using the Rotella just makes it more convenient....one oil for everything, just one oil to keep around. Not talking about a couple engines, this is 8 large farm tractors, 2 payloaders, 4 farm trucks, and all my small engines, so simplifying does help. Plus, it works fine, many years of use have proven it reliable, at least in my weather zone.
