Someone was asking about the qt16 tiller attachment. I bought this attachment with a eliminator 1900 and had to cut the lift rod to get it to work on the 1900. But the lift rod is made for the 16. I have no idea what tractor model the tiller was made for but the more I look at it I think it will also work on the large frame if I had a set of large frame mounting arms. So as you guys know you gotta do a little giggery buggery sometimes to get the job done. (dont flip me too much about the lift setup) I will tell you that you must I repeat must put 2 heater hose clamps on the PTO side of your driveshaft or it will fly off and do damage. I have 4 tiller driveshafts and 3 have a wobble from just that but I use them anyway. Also its not leaking oil or hydro I didnt know how many quarts of both to put in this spring for the annual change and put too much in both and suffered a little over flow. I will grab the tiller part # later. Gotta lot of work to do will post after I sit back and let the 16 till the garden. Need close ups post and I will get them ASAP.
