I figured I'd start a new thread, separate from the one I kept up that dealt with me just getting this tractor going. I've been using the tractor nonstop since I got it running last week, and of course, this is the best way to see what other outlying issues may still be lingering below the surface. I've essentially encountered two. One I guess is a little more bothersome than the other.
- For some reason, the tractor just decides to cut off after about an hour or an hour and a half of continuous use. I don't run it full throttle, usually 1/2 to 2/3. For most things, I keep it in 2nd, sometimes 1st, and only drive it in 3rd when I'm done for the day and taking it back down the road, not pulling anything or putting any kind of load on it. If I let the tractor sit for 20-30 minutes, I can go back to it and it starts right up and I get another hour or so out of it. I get that it is overheating in some way (I guess), but I have no clue where to begin troubleshooting. My mom told me that my dad put up with the same issue for years while he used it. He was a mechanic with 40+ years under his belt, and it even baffled him. It'd be nice to pinpoint and solve the issue.
- I was plowing up an old flowerbed yesterday and the hydraulic lift just stopped working. Thankfully it just seems to be the belt on the pump not catching tightly enough to spin the pulley. But on initial look, I can't for the life of me see how to tighten the belt or replace it. Do I have to disassemble everything just to get the belt off and a new one on? At least how do I tighten the belt, or can it be tightened?
