l recently purchased a [All Power America APG3014] 2,000 Watt 3 HP 4-Stroke Gas Powered Portable Generator (made in China, of course). I have done some simple testing.
1) I find it hard starting from cold - no primer, just a choke. Carburetor is not adjustable (I believe there is no access to the mixture jets). But it starts after 10 pulls or so.
2) I have tested with up to 750 watt resistive (heater) and it seems to hold fine.
3) It will not run an 8 amp 120 VAC (run, not start) electric chain saw. When I pull the trigger the engine immediately stops. Could be too lean, and I guess there is next to no weight on the flywheel. Other problems suggested or maybe just too much governor delay?
4) To the SUBJECT, the engine governor will pick up a 150 watt light and a 750 watt heater and seem to carry the load. But, when the load is removed the governor continues to hunt for the right RPM. The governor linkage is clearly visible and the movement is very slight, maybe 1/4" back and forth. Does this indicate a problem (maybe too lean), or do governors in general have trouble settling to a stationary state when there is no load on the engine?:dunno:
