Make a power king 1617 sub compact tractor go faster?
11K views 19 replies 7 participants last post by  willy1094
#1 ·
I have recently rescued a power king 1617 from rotting into the ground and i fixed it up and repowered it with a brigs and stratton 16hp vtwin, it is a 4 speed + rev gear drive trans, one problem i have is that i do alot of driving on the road but this tractor seems to go sorta slow, does anyone know how i could make it go a little bit faster? thanks Nick S :greendr:
#3 ·
You can do what chuck said, if it has thr high low, witch it should if its plastic. Also you can put larger tires on it. Not sure how much room the fenders have, and I don't think you can raise the fenders like older steal bodies. You could always take the fenders off. were in ny are you? Im in the lower hudson vally
#4 ·
you could take the transmission pulley off and put a smaller one on, it will speed it up but you'll have to buy a new belt too
#5 ·
power kings are shaft drive
#13 ·
hi,
I spoke before I checked my sources.
I had a "plastic" 1214 for a short time before I passed it on to someone else and thought it had a 2 spd rear.
I've since checked 1985 and 1988 owners manuals and see no reference to 2 spd rears.
In the specs the top speed for a 1617 in high gear was 5.7 mph (31" rear tires).
chuckbob
#14 ·
I would check your literature again. The plastic tractors, both 4spd and hydro, had 2spd rears.
#17 ·
its a plastic one. i dont think the have jim dandys. i believe its just power king
#19 ·
I don't know anything about them either. I geuss they could have the same rear, they have the same tranny I believe. I've never had a plastic one and I don't plan to own one.
