is this repairable or should I replace the engine?
yesterday I bought a good running Vermeer ride on ditch machine that has bad digger bearings. It’s a
From my research the Kohler was a 22 hp motor. The Vermeer is 30 hp. That would be a pretty good upgrade. The way the hydraulics are setup I feel I can move the mounts to match the Vermeer motor. Vermeer has a bell housing on 1 side and horizontal shaft on the other. I'll only need the horizontal shaft for the Roller. I'll get pics of all to show explanation. I'm currently COVERED in tractor projects and I'm a 1 man show with full-time job and 2 little kids!If you are willing to take the time, it appears that there may be enough 'meat' to use a brace 'plate' to bridge the fracture. If you can gain clear access you could drill and tap towards the block and use a nut and bolt outboard, perhaps with a third nut and bolt below the level of the starter. The first would need tapping so as to not disturb the starter mount position, the others not necessary. (from the pics as I see them).
Would a steel plate have enough strength? I think so, as it would need to support the weight of the starter and the torque it produced while spinning the flywheel. It is easier than fitting the V from the Vermeer? I suspect so. YMMV. Good luck whichever way you go.
tom
