Got a JD 235 in great condition I just picked up with the Briggs V Twin. Pretty sure it’s a Tough Torq K71 transaxle and I have a leak. Fluid is right at the “add” line in the overflow tank and the transmission itself is full because of I crack the black cap on the left side it starts coming out. Transaxle runs great and never skips a beat even after an hour of mowing on hills so I’m positive it’s in good working order. I do however have this leak. You can see where the build up is concentrated around there and it does look more wet than anywhere else bird it’s hard to see. It’s “oil wet” on the bottom of the transmission and you can see a drip hanging in the bottom right corner of the pic. Is it common to leak from the hose at the overflow tank where it goes into the transaxle? That’s where it looks like it’s coming from. Any help is appreciated! Steer me in the right direction boys!
Fluid - Can I use 5w50 or 5w40 synthetic engine oil? If not, what can I use? I want to be sure to keep it full until I fix the leak.
I’d also like to “upgrade” the washers I’ve read about in the axles to the hardened ones. What are they? Where do they go? Where do I get them?
