Jack Sheave Rebuild Question
1 reading
2.9K views 6 replies 4 participants last post by  gr8t73
#1 ·
As stated in an earlier post I am rebuilding the 48" mower deck on my 97 345. I recieved a lot of helpful information from the forum members in response to that post and I greatly appreciate it. My next question is in regard to the double pulley jack sheave. While inspecting the deck I noticed the bearings in the jack sheave are rough and make a bit of rumble sound when rotated. My local john deere dealer wants more that $300 for a new jack sheave. I was wondering if the bearings can be replaced on the jack sheave and if so has anyone on this forum done this. If so I would appreciate any guidance, tips etcetera you can provide me. I thought about taking the jack sheave to a local small engine repair shop and having them replace the bearings if that's possible. Thanks in advance.
#2 ·
Here's what I found for your deck:
So yes, bearings can be removed! Remove bolt 17 And try to support pulley on something with a hole slightly larger than the bearing bore ( a large socket may work!). Resting on pulley flanges could damage pulley when driving bearings (2) out. Stick a punch into top bearing and push spacer (#20) to one side. This will allow you to tap bearing out. Turn pulley over, support, and tap 2nd bearing out. When reassembling, install a bearing, the spacer and slip bolt through to center spacer. I would then pack space between spacer and bore with grease, about 75%-90% full. This will displace air and prevent corrosion from moisture in air. Install 2nd bearing, bolt in place and done! Bob
#3 ·
It's a pretty easy job. I did it on my old deck - I had to buy a socket to fit the bolt and nut as I believe it's 1 1/4" with a pretty high torque spec. If I recall, the numbers on the bearings and visible so you can order from a third part very easily.
You could very easily take the assembly to the machine shop of your choice and have the bearings replaced.
Good luck
#5 ·
Good luck
I greatly appreciate the response I think I will try replacing the bearings myself. I think it's worth a try besides if can't get the bearings out I can always take to a machine shop.
#7 ·
Denver guy was right I easily removed the bearings and order replacements on Amazon. Bearings should be here Monday and I will then begin the deck rebuild everything seems pretty straight forward. For anyone interested the bearing number for the jack sheave was National 204BAR. I want to say thank you to everyone on this forum that responded to my post. The information was very helpful and saved me a lot of money.
