My tractor won't start. It has the abominable Husqvarna "Smart Switch". Went to start it yesterday
- Press the center button, the center button turns green
- Enter code.
- Center button turns green
- Press the center button, it turns blue indicating a successful code was entered then immediately:
- Battery and PTO lights start flashing. They flash for a minute or two and go out.
- Repeat, same behavior.
- I changed the "security" code just in case and have verified the correct code gets a blue button and the wrong gets red.
- I had a problem before caused when I had replaced the battery and missed reconnecting a black wire from the battery. As a test, I unplugged each connector and tested with each disconnected.
- I understand there is a six-page document for troubleshooting the Smart Switch but cannot find it on the Internet.
- I would prefer to replace the switch with a key switch as long as it doesn't bypass safety systems.
- If I can't, I don't want to buy a new switch until I can verify that it will in fact fix the issue by going through the diagnostics
- The tractor has been sitting outside and hadn't been started for a couple of weeks. It has rained but not that much.
- Ideas?
