Today I started tearing down the HT-20 that my Johnson 14 loader came on.
I plan to rebuild/restore this tractor as close to stock as possible.
This will not be a fast project, but one I will putter on as time permits.
Tractor model is 2087 and serial# is 0201006:
I removed all of the sheet metal, the engine mount bolts and all connections to the engine:
I have pulled the shear bolt from the u-joint that is on the rear crankshaft stub, and soaked it with PB Blaster, hoping to be able to move the u-joint on the shaft so I can remove the engine.
The engine is pretty well stuck, but will turn with a long enough cheater bar.
This thing is pretty grungy, with caked on dirt/grease/critter debris on every ledge.
This is the first Bolens I have ever had that has its original hydro fan still in place:
The steering gears are shot, the steering bridge hole where the steering shaft sits in it is seriously wallowed out, the axle, axle mount and spindle bushings are all extremely loose.
This will be a frame-up rebuild.
