HOW TO: Re-Run Chute Cables for Model #50 Snowblower
12K views 7 replies 6 participants last post by  dave_r
#1 · (Edited)
A few months back, I was looking for help -- as I had just acquired a JD 400 and a #50 Snowblower/Snowthrower that was not working well.
I did quite a bit of research, and I could not find a diagram on how to run the chute cables. I limped through the winter, with about 60 degrees of chute movement (LAME!). However, now that it is not negative 20, I have taken some time to get the cables run correctly.
Fortunately, the pulley/cable configuration is very similar to some other JD units! (Folks with more experience than myself probably would have figgered this out sooner....)
But, anyway -- here are some instructions that I found on the John Deere Manuals site, that also basically apply to Model #50.
The great news, is that I now have about 170 degrees of chute rotation!
Replacing Right Cable
  1. Rotate discharge chute to the right (as viewed from machine seat) and verify that the hydraulic cylinder rod is retracted -- you may need to start the tractor up, to actuate the cylinder.
  2. Standing at rear of snowblower, put cable through hole (A), then loosen the bolt holding the right pulley (C), and place the end of the cable under the pulley's washer (re-tighten the pulley).
  3. Wrap cable around middle pulley (B), and around right pulley (C).
  4. Wrap cable counterclockwise around discharge chute and put it around threaded stud and behind washer and locknut (D).
  5. Here is a diagram of the right side cable:
Replacing Left Cable
NOTE: For ease of assembly and proper cable routing, replace one cable at a time. Route right cable around snowblower first, then route left cable.
  1. Keep the snowblower discharge chute rotated to the right (as viewed from machine seat).
  2. Standing at rear of snowblower, put cable through hole (A), then loosen the bolt holding the left outside pulley (C), and place the end of the cable under the pulley's washer (re-tighten the pulley).
  3. Wrap cable around middle pulley (B), and around left pulley (C).
  4. Wrap cable clockwise around discharge chute and put it around threaded stud and behind washer and locknut (D).
  5. Here is a diagram of the left side cable:
[*]Here is a diagram of both cables:
Finally, I will add that these directions are not quite perfect: my chute was about 60 degrees off, so I loosened the cables, fired-up the tractor and moved the actuator so that it was halfway extended. Then, I centered the chute (pointing forward), and cinched-up the cables.
#3 ·
The Generac is a total joy to use. I can mow my 2 acres in about 1:20. (Which is remarkable, considering how much rain we are getting this year.)
I tried pretty hard last winter, but could not get it to bog-down while blowing snow. Despite being a single stage, I was still seeing jets of snow that landed 25+ ft away from me.
Do you have a link for where I might find a long chute? --Am I right in assuming the long chute helps with distance? Or other?
#6 ·
Hey is it possible to get these diagrams re uploaded or made visible?
I am in the exact same scenario where I have to replace both cables and have a heck of a time replacing them (damaged four cables).
I originally thought each cable needed to be routed to its closet side which caused the cable to almost rip through the metal eye on the chute and bent the middle pulley.. doh.
Then I found the manual and routed the cables after determining the overall cylinder length and fixed the middle pulley being bent. I have 1/4” when fully retracted.When fully extended cylinder goes to 4 1/4” or 4” of travel. Split the distance to 2 1/4” or 2” each way for travel and placed the chute in the middle (facing forward). This let the chute travel all the way to the left perfectly 90% but not much past straight to the right when viewing from the seat. I tried adjusting cables some more and then everything went to heck. Also the one cable wants to keep jumping off the middle pulley. I’m thinking it’s because of the cable routing order. I had started on the right or furthest away from the cylinder first because it’s supposed to sit on the bottom of the pulley. That seemed to be correct. Until it jumped off n wants to jam again. Inherently it seems like a poor design with only one pulley for two cables in the middle.
