Help me please if you own a Cub Cadet LTX1050
9.5K views 4 replies 3 participants last post by  Joewildlife
#1 ·
So my dogs enjoyed chewing up and tearing out some of the wiring on my LTX1050, as you can see.
If you want to help a guy out, can you go take a pic or two of the wiring visible under the area of the starter?
Specifically:
  • There is a green and red wire coming from the left, and another red wire from the left with a black spade connector.
  • There is a black wire and a green/white wire coming from the top of the picture.
  • what wire connects to the rectifier?
  • what wire connects to a male/female connector torn off the black wire?
  • what wire connects to the male/female connector on the green/white stripe wire?
  • in what location does the green jumper wire get plugged back into the white plug?
  • what does the red wire with the black plug go to?
  • I'm pretty handy but I can't figure out what is what. One of the wires I mentioned goes to the headlights, but that harness is completely gone but I don't care about that. I just need to get the thing running again. It won't start now.
Thanks for any help you can provide!
Joe
#5 ·
update: got it running. figured out with help from the wiring diagram and some internet/youtube videos. Got 12V switched power back to the carb solenoid, and 12v battery power to the voltage regulator. the headlight harness is gone gone, but no biggie. The black wire I think goes to the oil pressure cutoff switch. If I ground it the mower dies so screw it. The charging circuit is working fine. She runs now. thanks.
